How to Change RotateOrigin when using EditToolbar "esri/toolbars/edit"
2183
06-08-2016 10:16 PM
SumitZ
New Contributor III
While using Editing tools | ArcGIS API for JavaScript​ is thier any way to rotate the polygon from specific rotateOrigin instead of centroid of the polygon.
We have the option to set the rotate origin when using geometryEngine.rotate() function [esri/geometry/geometryEngine | API Reference | ArcGIS API for JavaScript ] in same way i would like to rotate the polygon using EditToolbar but would like to rotate it around the different rotateorigin than the centroid of the polygon.
Sumit Zarkar
SumitZ
New Contributor III
Robert Scheitlin, GISP​ any idea on this.
Thanks.
RobertScheitlin__GISP
Sumit Z,
  This this type of control exists in ArcMap there is nothing in the JS API to allow this type of control.
