Registering a spatial view in Oracle database
6155
9
06-09-2016 03:15 AM
HaniDraidi
Occasional Contributor II
How can I register a spatial view with an enterprise Oracle geodatabase?
What kind of code should I use in ArcSDE Command line? I am not aware of the registering code that should be used for oracle spatial views
Any help is highly appreciated!
VinceAngelo
Esri Esteemed Contributor
There are a number of existing threads giving this exact information, which could be located by using this question's title in the search bar (though fewer terms are better -- "register spatial view" would locate my answer to your previous question).  Please remember to include complete version details, for the version of ArcGIS in use, and for the database, in each post.
- V
HaniDraidi
Thanks for the valuable contribution Vince,
I am using Oracle 11g with ArcGIS Server 10.3.1. I searched for simillar posts for Oracle, but I did not find. May you please point me to a proper thread that can help me?
Kind Regards,
VinceAngelo
The command syntax is exactly the same as the answer provided.  All that changes is the direct connect instance flag and the client library configuration.  Command-line tools are no longer supported, so if you are going to try to use them, you'll need to be creative.
A complete description for Oracle includes FIVE digits of release information (11.a.b.c.d)
- V
PanagiotisPapadopoulos
besides SDE commands an another way is to create a simple view from ArcCatalog
just add a simple sql statement
in order to create a registered sde view
finally from Oracle SQL Developer open and edit the sql statement in order to be the desired.
HaniDraidi
Thanks Panagiotis for the helpful input,
Actually, what I am asking for is how to register the created spatial view (after creating a view with SHAPE field) with the oracle enterprise GDB?
This also can be used for the existing views.
Create the simple view from the ArcCatalog and replaced the sql statement with what you have in the existing View.
This is a spatial view, if you see in the previous images the view ignored as SDE Feature Class.
HaniDraidi
Dear Vince,
As you mentioned above that Command Line Tools is no longer. I all the time wonder what is the new relative? I read a lot of articles published by Esri about this, but I never found how I can register a spatial view with enterprise GDB. May you please elaborate more how I can do this without ArcSDE Command Line Tools?
Best,
George_Thompson
Esri Frequent Contributor
There is no other way at this time to register a view with the geodatabase outside of the SDE command line tools (to my knowledge).
There have been many post related to this topic on GeoNet and ArcGIS Ideas. I found these post by searching GeoNet.
Spatial view metadata
Spatial view Problem -- Another GeoNet post by you for SQL Server
register with gdb
https://community.esri.com/ideas/8897
How to create an SDE View in 10.3
***Updated: Here is another thread on GeoNet that covers most of this in detail. It has lots of comments and dialog on this issue***
Alternatives to using SDE command line tools - Blog Discussion
--- George T.
DanMcCoy
Occasional Contributor III
"Coming at the 10.5 release the ‘Register with Geodattabase’ tool will be enhanced with additional parameters and allows database views as acceptable input datasets." https://community.esri.com/ideas/8897#comment-42312
