AnsweredAssumed Answered
Map Service properties (arcpy): Error parsing recycleInterval, recycleStartTime, keepAliveInterval
Question asked by abreufreire on Jun 8, 2016
Latest reply on Jul 14, 2017 by hvamelsvoort
Need to publish web service using arcpy tuning up its properties through the parameter names passing them into function parameter_toggle (see code bellow). We are getting error (see picture bellow) in the parse of XML (output of sddraft analysis) with xml.dom.minidom for the parameters:
- "recycleInterval"
- "recycleStartTime"
- "keepAliveInterval"
These parameters represent service properties:
Specify Recycling Settings:
     - Recycle this configuration every
     - Starting at
Specify Health Check Settings:
     - Check and repair instances every
def mapService(wrkspc, con, service):
   return (sddraft, analysis) # (out_sddraft, out_analysis)
def capability_toggle(doc, server_type, status):
  type_names = doc.getElementsByTagName('TypeName')
   for type_name in type_names:
   if type_name.firstChild.data == "{}".format(server_type) and status.lower() == 'on':
  type_name.parentNode.getElementsByTagName("Enabled")[0].firstChild.data = "true"
def parameter_toggle(doc,'maxRecordCount', 'MaxInstances', 'recycleInterval', 'recycleStartTime', 'keepAliveInterval'):
  keys = doc.getElementsByTagName('Key')
   for key in keys:
   if key.firstChild.data == "{}".format(maxRecordCount) : key.nextSibling.firstChild.data = 100000
   if key.firstChild.data == "{}".format(MaxInstances) : key.nextSibling.firstChild.data = 5
   if key.firstChild.data == "{}".format(recycleInterval) : key.nextSibling.firstChild.data = 20
   if key.firstChild.data == "{}".format(recycleStartTime) : key.nextSibling.firstChild.data = '04:00'
   if key.firstChild.data == "{}".format(keepAliveInterval) : key.nextSibling.firstChild.data = 86400 #seconds
def publishService(out_analysis, out_ssdraft, sd, con):
def main():
   # workspace
  wrkspc = "path_to_workspace"
   # server connection (publisher)
  con = os.path.join(wrkspc, "file.ags")
  service = "service_name"
   # outputs mapservice
   (out_sddraft, out_analysis) = mapService(wrkspc, con, service)
   # parse of XML (from sddraft analysis)
  doc = dom.parse(out_sddraft)
   ### ERROR HERE PARSING XML ###
   with open(out_sddraft, 'w+') as xml:
  capability_toggle(doc, 'WMSServer', 'on')
  doc.writexml(xml)
  sd = os.path.join(wrkspc,service + '.sd')
  publishService(out_analysis, out_sddraft, sd, con)
if __name__ == '__main__':
  main()
Outcomes
