Conflict with URL Link and keepAppState
2878
7
06-07-2016 10:11 AM
RichBell
Is there a way to set the "keepAppState" to "true" as a default but then set the
"keepAppState" to "false" when performing a URL search with the eSearch Widget?
The eSearch Widget will fail "no results" if "keepAppState" is set to "true"
Thank You
Rich
RobertScheitlin__GISP
Rich,
  Could you expound on this a little? Are you saying that using the eSearch URL search and then clicking on the popup that asking about restoring the apps state causes you issues?
RichBell
Yes, if I use this string with the keepAppState set to false it works great
http://gisapp.mahoningcountyoh.gov/MAHGIS/index.html?esearch=53-057-0-197.00-0&slayer=0&exprnum=0
but if I set the keepAppState set to true it fails.
Is there be a way to disregard the keepAppState until the eSearch widget completes the search, otherwise the keepAppState setting is of no value
Rich,
Are you making code modifications to set the keepAppState by default?
RichBell
I have not
I only set it in the config file as false or true
Rich,
  I have tested on my eSearch Live Preview site and on my dev machine and I can find to conflict between the eSearch URL search parameter and the keep app state...
RichBell
My bad !!.
I just cleared the internet cache completely and it does work being set to true.
So sorry
Rich,
  Glad to hear that. Please mark this thread as answered so we can close this one out.
