Problem drawing marker symbol on export
3070
06-03-2016 06:29 AM
PatricePineault1
New Contributor III
There is something wrong happenning when exporting a map (I tried JPEG and PDF). For some reason, the marker symbol (which is a picture marker symbol) is not drawn correctly. And for some reason, the other ones to the left of the map are OK. The broken symbol is drawn correctly if I drag it to the left of the map. I tried different symbols and it does the same thing.
I attached a picture of the problem and another one of what is should look like.
I used style manager to create a Marker symbol and I choosed a Picture Marker Symbol. The picture itself is a png.
PatricePineault1
New Contributor III
I forgot to mention that I am using ArcMap 10.4
RobertScheitlin__GISP
Patrice,
You will be better off calling esri tech support on this question.
PatriceMarseille
Patrice,
did you find how to solve this problem?
I have the same problem and with the same symbols from the MTQ directory.
Thank you
