android 6.0 ,open .geodatabase file err
3608
06-03-2016 01:37 AM
dgterydgt
after android runtime update,tip java.lang.RuntimeException: Unable to open the database file
AlexanderNohe1
Occasional Contributor III
You need to enable runtime permissions for access to external storage at Android API 23.  If you are compiling/deploying to API 22 or below this is not required.  See the following help documentation:
Requesting Permissions at Run Time | Android Developers
by Anonymous User
Not applicable
I don't know if this helps but I am noticing in Android M (6.0) when pointed at SD Card that some environmental variables no longer work even with permissions setup correctly.  For example I had to change the following...(there are probably other ways to do this also).
System.getenv("SECONDARY_STORAGE")
to a little more convoluted method to get SD Card path...
if (Build.VERSION.SDK_INT >= 23) {
   for (File file : mContext.getExternalFilesDirs(null)) {
       if (file.getPath().contains("emulate")) {
       }else{
              File fileParent = file.getParentFile();
              appSDPath = fileParent.getPath() + "/Reference_Data";
              appSDPathApplication = fileParent.getPath();
}else{
   appSDPath = System.getenv("SECONDARY_STORAGE") + "/Android/data/com.company.app/Reference_Data";
AlexanderNohe1
dgtery dgt​,
Did the above suggestions help?  Are you still having issues?
YueWu1
by Esri Regular Contributor
Hi dgtery dgt​,
Make sure you enable the permission in your AndroidManifest.xml, you probably not give the WRITE & READ permission.
<uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" />
<uses-permission android:name="android.permission.ACCESS_FINE_LOCATION" />
<uses-permission android:name="android.permission.READ_EXTERNAL_STORAGE"/>
Install and set up—ArcGIS Runtime SDK for Android | ArcGIS for Developers
Hope this can help.
