AnsweredAssumed Answered
Postgresql and Arc SDE / Server
Question asked by yeel on Jun 2, 2016
Latest reply on Jun 3, 2016 by yeel
I was recommended to post a question here from this thread. I have been following the instructions here and copied over the ST_Geometries.dll and the other postgre libs into their respective ArcGIS and ArcServer Libs. The first question I have is: if I created tables in postgre, is the geometry I created below the correct type for Arc to read it? I am having an issue opening or editing tables I created in SQL with arcCatalogue, and when I open feature classes they open as a query layer (see below). I am at a loss as to what else I can try. I am using ArcServer and ArcGis 10.4, PostgreSQL 9.2.17 and PostGIS 2.1.8.
I will re-post below:
Hi, I've set up postgre /postgis and enterprise SDE. An example of my sql for setting up a table follows:
CREATE TABLE bird_sighting (
    bird_id integer PRIMARY KEY,
    field_id integer REFERENCES field(field_ID),
    birdev_id integer REFERENCES bird_event(birdev_id),
    sight_date date NOT NULL CHECK(sight_date > '2016-05-01'),
    activity character varying (30),
    rel_location character varying (20),
    species character varying (40),
    geom geometry(Point, 26917) NOT NULL
When I open this feature class in ArcMap it opens up the "neq query layer" dialogue:
Is this correct? I thought that if I already defined the SRID and geometry type that this should already be populated?
Can someone explain to me why arcmap does this, or perhaps what I am doing wrong?
Outcomes
