Sequential field calculation with Python
3827
06-01-2016 07:35 AM
KatyW
New Contributor III
I'm trying to field calculate some records that have a null value.  I used the following code from the ESRI help section on sequential calculations.  It worked!  Now I need to modify the script a bit.  This code gives me a sequential order of single digits.  I would like to have some zeros before the new assigned digit.  0001 instead of just 1.  How do I add the three zeros before the assigned digit?  I would like a four digit value in the end.  0001, 0002, 0003, etc.
Thanks!
Here's the python code I used:
Parser:
Python
Expression:
autoIncrement()
Code Block:
rec=0
def autoIncrement():
    global rec
    pStart = 1 #adjust start value, if req'd
    pInterval = 1 #adjust interval value, if req'd
    if (rec == 0):
        rec = pStart
    else:
        rec = rec + pInterval
    return rec
ChristianWells
Hi Katherine, you can return these values as strings with numbers prefixed by zeros using the zfill method.
Python String zfill() Method
num = 1
str(num).zfill(4)
'0001'
ChristianWells
num = 1
str(num).zfill(4)
'0001'
KatyW
New Contributor III
Where do I add this into my code?  Or is this string code a separate process?
KatyW
New Contributor III
Here is the solution!
Use the original script to sequentially order.  After that is done field calculate again using the field you wish to add the extra digits to.  Then you can choose the string type as .zfill and add as many zeros as you would like.  I attached a screen shot to help clarify.  This gave me the result I was looking for!
ChristianWells
Fantastic! Glad this worked out for you.
