I'm trying to create some offline content for the ArcGIS Runtime using the Desktop Pattern (export data using ArcMap).
Some of the layers in ArcMap have an advanced labeling like (VBcript) "[Field_1] & [Field_2]". Unfortunately, the Create ArcGIS Runtime Tool fails with the message "Layer expression not supported".
As the ArcGIS Runtime is able to handle such a label expression as described in Label map features—ArcGIS Runtime SDK for .NET | ArcGIS for Developers , referring to the ArcGIS Server REST API "[Field_1] CONCAT [Field_2]", I wonder how to prepare the data in ArcMap to avoid having custom code in ArcGIS Runtime. I tried all VBScript, JScript and Python but eventually failed.
Is it possible to prepare the Labeling expression in ArcMap in a way, the Create Runtime Content tool supports the conversion?
Kind Regards
Jens
