Cannot enable offline
1851
05-29-2016 11:18 PM
PublicGardens
i have a web map that i cannot take offline. i get an error when i "enable offline" : Wb map can not be taken offline ... bla bla.
GISSupport3
Occasional Contributor III
Double check you have followed all the steps in Prepare maps for offline use—Collector for ArcGIS | ArcGIS
If still not working check the ArcServer Manager logs AND the local drive logs.
Main issue we have are unsported symbology, though no reference to such in error message.
PublicGardens
can you please specify what should i check in both the arcserver manager and local drive logs.
PS: everything was working fine, until our client decided to change  the domain name !
GISSupport3
Just read and see if anything gives you a lead though ...
based on everything working before a DNS change ... check none of the map links point to old name.
Use ArcGIS Online Assistant to see.
