How to unregister a replica when a local geodatabase is removed?
2623
05-23-2016 04:24 AM
by Anonymous User
Not applicable
When an offline geodatabase is created from a feature service, a replica is created on the server so that they can be synchronized. When the offline geodatabase is removed from the device, the replica can (should) be removed from the server as it is no longer required.
Does anyone have examples of how to go about unregistering the replica that was linked to a particular offline geodatabase?
I can't see any properties or methods of the Geodatabase object that might reveal the associated replica id. If we at least knew the replica id, then could use a NetworkRequest to unregister it.
-Paul
LucasDanzinger
Esri Frequent Contributor
Hey Paul,
The unregister method on GeodatabaseSyncTask should do what you need - ArcGIS Runtime SDK for Qt QML API: GeodatabaseSyncTask Class Reference
-Luke
LucasDanzinger
Hey Paul,
-Luke
by Anonymous User
Not applicable
Thanks Luke!
nakulmanocha
When you create a geodatabase using GeodatabaseSyncTask::generateGeodatabase, the replica is created and the local database is ready to be edited and synced. If you don't any further syncs or you wanna share that geodatabase, you need to unregister it. It can be done by using [ GeodatabaseSyncTask::unregisterGeodatabase(Geodatabase geodatabase) ].
After that you can go ahead and delete the geodatabase. I hope this helps.
by Anonymous User
Not applicable
Thanks Nakul
