Question about simple layout
2051
05-23-2016 02:42 PM
LeiZhou1
I try to do a simple test, just add a map and its title to a html file. But at the right-bottom corner, there is always space, and the vertical scroll bar always exists. I want the map and title display as a whole thing without any vertical scroll bar. See my codes below and the Pics. I have set the div container as 100%, but why the vertical scroll bar is not gone? Thanks!
<!DOCTYPE html>
     <html>
        <head>
            <title>Testing Map</title>
            <script src="https://js.arcgis.com/3.16/"></script>
            <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
<style>
      html, body, #map, #container{
        height: 100%;
        margin: 0;
        padding: 0;
    </style>
       </head>
        <body>
       <div id="container">
            <div>Map Title</div>
            <div id="map"></div>
        </div>
<!-- ESRI JS API Element-->
       <script>
                  var map;
                  require(["esri/map", "dojo/domReady!"], function(Map) {
                  map = new Map("map", {
                 basemap: "topo",
                  center: [-122.45, 37.75], // longitude, latitude
                  zoom: 13             });
          </script>
         </body>
        </html>
RobertScheitlin__GISP
Lei,
  Here is another way if you do not want the title on the map:
<!DOCTYPE html>
<html>
<head>
    <script src="//js.arcgis.com/3.16/"></script>
    <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.16/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.16/esri/css/esri.css">
    <style>
        html,
        body,
        #map {
          width: 100%;
          height: 100%;
          margin: 0;
          padding: 0;
        .claro .dijitContentPane {
            padding: 0;
    </style>
    <script>
        var map;
        require([
          "esri/map",
          "dojo/parser",
          "dijit/layout/ContentPane",
          "dijit/layout/BorderContainer",
          "dojo/domReady!"
        ], function(Map, parser) {
          parser.parse();
                basemap: "topo",
                zoom: 13
    </script>
</head>
<body class="claro esri">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false, liveSplitters:false" style="width:100%; height:100%;">
    <div id="bot" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top', splitter:false" style="height:22px;">
    </div>
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center', splitter:false" style="height:100%">
    </div>
  </div>
</body>
</html>
</html>
RickeyFight
MVP Regular Contributor
Try:
<!DOCTYPE html>
     <html>
        <head>
<style>
        height: 100%;
        margin: 0;
        padding: 0;
      .Title{
        position: absolute;
            z-index: 1000;
    </style>
       </head>
        <body>
           <div class= "Title">This is your Map Title</div>
            <div id="map">   </div>
        </div>
       <script>
                  var map;
                 basemap: "topo",
                  zoom: 13             });
          </script>
         </body>
        </html>
Lei,
<!DOCTYPE html>
<html>
<head>
    <style>
        html,
        body,
        #map {
          width: 100%;
          height: 100%;
          margin: 0;
          padding: 0;
            padding: 0;
    </style>
    <script>
        var map;
        require([
          "esri/map",
          "dojo/parser",
          "dojo/domReady!"
          parser.parse();
                basemap: "topo",
                zoom: 13
    </script>
</head>
    </div>
    </div>
  </div>
</body>
</html>
</html>
