AnsweredAssumed Answered
WAB Application prompts for portal login
Question asked by rhasseea on May 23, 2016
Latest reply on Sep 12, 2016 by gkmcbride
Hi we are using Portal for ArcGIS and Web Adaptor 10.4 which are configured with IWA and Windows Authentication. We have setup a webmap which contains a number of layers from ArcGIS Server map services. Both Portal and ArcGIS Server are configured with HTTPS only. The webmap is shared to a a particular portal group, which the user is a member of.
We have then built a web application using WAB Developer Edition, and hosted on a separate web server.
When using the Out of the Box Print or Measurement widget from the web app, it prompts for login to the portal (attached)
Has anyone come across a similar issue?
Outcomes
