Geometry is not M-aware issue with Polygon Neighbors
5276
05-19-2016 08:32 AM
TatyanaDeryugina1
I'm trying to calculate which CA zip codes border each other using Polygon Neighbors. I keep getting the error that the "Geometry is not M-aware". Initially, the dataset did not have M-values. I added them using "Feature Class to Shapefile" and turning on M-values in the Environment options. I also repaired the Geometry. I tried running Polygon Neighbors with disabled M-values in the Environment options. Same error every time. I don't know what else to do.
The dataset to which I added M-values is attached. FYI, I'm using ArcGIS 10.4
DanPatterson_Retired
the shapefile has issues, but it isn't the shapefile itself.  You need to add it to a geodatabase as suggested in this thread
What is a file geodatabase?—Help | ArcGIS for Desktop
so you can try converting the shapefile to a filegeodatabase, making it m-aware using
Feature Class to Feature Class—Help | ArcGIS for Desktop
then try to see if the tool works.
According to the reference thread it solved their problem
TatyanaDeryugina1
Thank you for the suggestion, Dan! Unfortunately, that did not work for me. I created a geodatabase, converted the shapefile to a geodatabase using "Feature Class to Geodatabase", then tried running the Polygon Neighbors tool on the Geodatabase file. The good news is that it didn't give me a geometry error; but it still gave an error (a pretty uninformative one, basically that it failed to execute). I also tried the "Feature Class to Feature Class" conversion after creating a Geodatabase, but that gave a geometry warning as well.
Fortunately, I found a workaround. I just converted the polygons to lines and checked the box that reports bordering FIDs, which is all I really needed.
