Difference between !shape.area! and Calculate Geometry > area
21370
35
05-18-2016 05:46 AM
I have a shapefile with 62.000 polygons.
I have created two fields (Double) AREA1 and AREA2 with identical properties.
On AREA1 I have calculated the area of polygons with Calculate Geometry > area process.
On AREA2 I have calculated the area of polygons with Field calculator and the command: !shape.area!
When I compare the difference between the two fields ([AREA1] - [AREA2]), I find 30 polygons with no zero difference less than 0,01 square meters.
Is there a different algorithm for these processes?
Does anyone know why is this happening?
DanPatterson_Retired
does the file have a defined coordinate system?  problems in calculating shape geometry arise when there is no know coordinate system.  This is well documented on this site.
The shapefile has a coordinate system defined (Greek Grid).
I tried yesterday after publishing my question to calculate with and without defined Projection and the result was the same.
Two things to check
  • the dataframe and file are in the same coordinate system
  • run a repair geometry on the file to correct any unseen geometry errors
The check geometry found no errors but I run Repair Geometry.
The dataframe in on the same coordinate system.
The difference remains!
Pagagiotis.... export and post a  sample, I would be interested in seeing this vagrant shape set since I am interested in computational geometry issues.
JoshuaBixby
MVP Esteemed Contributor
What version of ArcMap are you running?  It always helps to know the versions of software we are discussing.
I am using ArcMap 10.3.1 on Windows 10 Pro.
any chance on the sample geometry?
I will provide it tomorrow.
