AnsweredAssumed Answered
How can I duplicate the popup behavior from Shortlist template to Map Series template?
Question asked by cmathers on May 16, 2016
Latest reply on May 17, 2016 by cmathers
I want to use the Map Series story map template but would like the popup behavior from the Shortlist template. In Shortlist you get a popup with a button at the bottom for more information which expands gives a small info window which has the popup content and more content in a second column. I edited the Map Series CSS to make the default popup wider and used a table in the popup so it will format to two columns but it doesn't look as nice. Anyone played with these templates code enough to give me a direction to head in?
Outcomes
