AnsweredAssumed Answered
thematic mapping for a feature layer does not show colors. need help.
Question asked by muralidhar.moka on May 13, 2016
cannot render a thematic map, color wont show.
Hi trying to create a thematic map for a feature Layer. Here is what I did.
I. created a map.
2.Created a basemap layer and added it to the map.
3.created a feature layer and added it to the map.
4.then tried to use the smartMapping.createClassedColorRender  ( I set baseMap like baseMap:map).
5.what I get is I only see the featurelayer boudries with some color. but the featureLayer polygons are not colored.
may be in step 4. I did not set my baseMap layer correctly(do not know how to do it). Can any one help me, what my mistake is.
I used the following as an example from ArcGIS javascript samples.
Smart Mapping - Render class breaks with color | ArcGIS API for JavaScript
Here is the code.
showThematicMap_back:function()
   //global vars
   var layer, legend;
   var controller = this;
   require([
   "esri/map",
   "esri/dijit/PopupTemplate",
   "esri/layers/FeatureLayer",
   "esri/layers/ArcGISDynamicMapServiceLayer",
   "esri/dijit/Legend",
   "esri/renderers/smartMapping",
   "dojo/_base/array",
   "dojo/dom",
   "dojo/dom-construct",
   "dojo/data/ItemFileReadStore",
   "dijit/form/FilteringSelect",
   "esri/Color",
   "dojo/parser",
   "dijit/layout/BorderContainer",
   "dijit/layout/ContentPane",
   "dojo/domReady!"
   ], function (
   Map,
   PopupTemplate,
   FeatureLayer,
   ArcGISDynamicMapServiceLayer,
   Legend,
   smartMapping,
   array,
   dom,
   domConstruct,
   ItemFileReadStore,
   FilteringSelect,
   Color,
   parser
   parser.parse();
   var mapPageController = controller.get('controllers.mapPage');
   var map = mapPageController.get('map');
   //select the filed Name
   var fieldName = "UNIT";
   var outFields = ["UNIT"];
   //create popup for template
  //label is just a text field that apprears on template
   var popupTemplate = new PopupTemplate({
   title: "{UNIT}",
   fieldInfos: [{
   "fieldName": fieldName,
   "label": fieldName,
   "visible": true,
   "format": {
   places: 0,
   digitSeparator: true
   showAttachments: true
   layer = new FeatureLayer("http://memgisdev.memphis.ad/arcgis/rest/services/DPD/Boundaries2010UTM16N/MapServer/0", {
   "id": "Washington",
   "infoTemplate": popupTemplate,
   "mode": FeatureLayer.MODE_SNAPSHOT,
   "outFields": outFields,
   "opacity": 0.8
   //set Definition expression to filter the features you want to show
  //layer.setDefinitionExpression("STATE_NAME='Washington'");
   map.addLayer(layer);
   layer.on("load", function () {
   createRenderer(fieldName);
   function createRenderer(field) {
   //smart mapping functionality begins
   smartMapping.createClassedColorRenderer({
   layer: layer,
   field: field,
   basemap:map,
   classificationMethod: "natural-breaks",
   numClasses: 10
   }).then(function (response) {
   layer.setRenderer(response.renderer);
   layer.redraw();
   createLegend(map, layer, field);
   //Create a legend
   function createLegend(map, layer, field) {
   //If applicable, destroy previous legend
   if (legend) {
   legend.destroy();
   domConstruct.destroy(dom.byId("legendDiv"));
   // create a new div for the legend
   var legendDiv = domConstruct.create("div", {
   }, dom.byId("legendWrapper"));
   legend = new Legend({
   map: map,
   layerInfos: [{
   layer: layer,
   title: "Census Attribute: " + field
  }, legendDiv);
   legend.startup();
Outcomes
