Esri Maps or JavaScript Applications for Filenet?
1116
05-11-2016 02:04 PM
GeoffreyWest
Occasional Contributor III
My organization has a legacy system which uses the Google Maps API to make a call to a Oracle database based on queries which are accessible on the client via drop down menus.  Once the query is made, several options are returned which meet the conditions.  Once one option is chosen a point on the appears with a link to a .pdf which is hosted in Filenet.  Is there a way to do this with Esri Maps for Sharepoint, WebAppbuilder, or JavaScript API?  The work flow is really straight forward, and our goal is to move away from Google Maps to a more enterprise solution in one of the above mentioned packages.
Tags (1)
RobertScheitlin__GISP
Geoffery,
  I can not speak of Sharepoint but the answer is definitely yes when it comes to JS API and WebApp Builder. Both would require custom development but as Google Maps uses JS as well the level of effort should be minimal.
