eSearch - Wrap Result Text
1750
05-10-2016 08:28 PM
RodWoodfordOld
Occasional Contributor III
Hi Robert
Is there an issue with the "wrap result text" function? I have ticked the box to wrap text but it doesn't work. The work around I'm using is to comment out the "white-space:pre" and the "white-space:pre-wrap" in the style.css, which works. Any advice would be good.
cheers
Rod
RobertScheitlin__GISP
Rod,
  Version 2.0.1.2 is now available that addresses this bug.
Rod,
  I see the issue. Somehow some code was omitted from two different files.
Widget.js (line 2):
_initResultFormatString: function () {
        this.list._wrapResults = this.config.resultFormat.wrap || false;
List.js (line 8):
return declare([_WidgetBase, Evented], {
      'class': 'widgets-Search-list',
      _itemCSS: "search-list-item",
      _itemSelectedCSS: "search-list-item selected",
      _itemAltCSS: "search-list-item alt",
      parentWidget: null,
      _wrapResults: null,
and in the add function (line 36 - 38):
add: function(item) {
        if (arguments.length === 0) {
          return;
        this.items.push(item);
        var div = domConstruct.create("div");
        domAttr.set(div, "id", this.id.toLowerCase()+item.id);
        var iconDiv = domConstruct.create("div");
        domAttr.set(iconDiv, "id", this.id.toLowerCase()+item.id);
        domClass.add(iconDiv, "iconDiv");
        domConstruct.place(iconDiv, div);
        var removeDiv = domConstruct.create('div');
        domConstruct.place(removeDiv, div);
        domClass.add(removeDiv, 'removediv');
        domAttr.set(removeDiv, 'id', this.id.toLowerCase()+item.id);
        var removeDivImg = domConstruct.create('div');
        domClass.add(removeDivImg, 'removedivImg');
        domConstruct.place(removeDivImg, removeDiv);
        domAttr.set(removeDivImg, 'id', this.id.toLowerCase()+item.id);
        domAttr.set(removeDivImg, 'title', item.removeResultMsg);
        this.own(on(removeDivImg, 'click', lang.hitch(this, this._onRemove)));
        var rTitle = domConstruct.create("p");
        domAttr.set(rTitle, "id", this.id.toLowerCase()+item.id);
        domClass.add(rTitle, "title");
        rTitle.textContent = rTitle.innerText = item.title;
        domConstruct.place(rTitle, div);
        if(item.alt){
          domClass.add(div, this._itemAltCSS);
        }else{
          domClass.add(div, this._itemCSS);
        if(this._wrapResults){
          domClass.add(div, "result-wrap");
Rod,
RodWoodfordOld
Thanks for the prompt reply and fix Robert.
cheers
Rod
