I am trying to strip "$" from attributes in the Name field or all the fields in a feature class table prior to exporting out the table.
Could you strip the "$" from attributes in the Name field or all the fields in arcpy.MakeQueryTable_management prior to exporting if so how? I am not sure which would be the fastest?
I have the following but i am getting an error on line 8.
Error:
line 8, in <module>
r.OwnerName = s.strip("$")
AttributeError: 'NoneType' object has no attribute 'strip'
import arcpy fc = "C:/Temp/Default.gdb/yogurt" rows = arcpy.UpdateCursor(fc) for r in rows: s = r.Name r.Name = s.strip("$") rows.updateRow(r)
Thanks.
r.Name = s.replace("$","")
but a None Type means you have blanks returning None
PS where did r.Ownername come from???
the r.OwnerName is a typo, it should have just been r.name = s.strip("$"), my bad.
How do make an exception for the None Type with my current code?
Can the $ be striped from a arcpy.MakeQueryTable_management?
Thanks.
Of course it can... assuming one could see the whole code section
This will skip the null fields and hopefully solve your problem.
Note, using arcpy.da.UpdateCursor may be 10-100x faster, making your question about the query table maybe not that important...
with arcpy.da.UpdateCursor(fc, "Name") as rows: for r in rows: if r != None: r[0] = r[0].replace("$", "") rows.updateRow(r)
