Sid Files not working in catalog
4261
12
05-05-2016 01:28 PM
EmmanuelJohn1
I hope everyone is doing fine.
    I recently downloaded sid files to develop a raster. For some reason I am unable to view them in arc catalog nor arcmap. When I try to open up its properties I get a "Failed to open dataset error". "Invalid raster dataset. Failed to create raster layer" followed by "Could not add specified data object to the map" are the errors fo get for arcmap.
DanPatterson_Retired
which mrsid type since they are both supported Supported raster dataset file formats—Help | ArcGIS for Desktop
where do you have them stored/saved that they can't be opened ... locally? on a network?
EmmanuelJohn1
I'm trying to work with them locally. they are .sid and .sdw files. I can see that they exist, but can't preview them.
And you said you can't add them to a new data frame in ArcMap?
EmmanuelJohn1
That is correct. I got the files through here. If it helps to recreate the isuue.
https://njgin.state.nj.us/NJ_NJGINExplorer/IW.jsp?DLayer=NJ%202015%20Orthophotography%20MG4
downloaded one... you forgot to unzip the file perhaps?
EmmanuelJohn1
haha...im having trouble after the unzipping.
NeilAyres
Ditto, works wonderfully.
That is an amazing resource you have there in NJ.
EmmanuelJohn1
Neil what version of arcmap is that?
EmmanuelJohn1
Also what window OS is on ur machine?
