Versioned Layer and attribute table widget
1597
05-05-2016 09:48 PM
RamónVélez
My application programatically changes the layer gdb version but the attribute table widget keeps showing the information for that layer's default version. Since I'm changing the version for the layer I'm getting from the webmap, I expected the attribute table to show info for that layer's version only. Is this the expected behavior? What can I do to make the attribute table show only information for the gdb version the layer is using?
The application is a custom application created with Web AppBuilder Developer Edition and uses custom widgets.
Thanks in advance,
Ramon
Cristian
Hi Ramón
I have the same problem and it is happing with othes widgets too.
Did you find some solution?
Cristian
