AnsweredAssumed Answered
Portal 10.4 Help: Edit visible columns for query results attribute table
Question asked by rockchick86 on May 4, 2016
When I use the query widget to perform a task, I specify my parameters and check "add result as operational layer". I click apply and then open the layer list widget. I click on the arrow pointing down next to the query result layer and "Open Attribute Table".
Is there any way to modify the columns that are displayed for these query results? I am curious as to how Portal is choosing the 4 columns that I see in the attribute table, seeing that they are in a different order than what is in the actual layer.
Also, when you perform a query, is there any way to limit what is show on the map to just those query results?
Outcomes
