AnsweredAssumed Answered
Find Task
Question asked by burnaby on May 3, 2016
Latest reply on May 4, 2016 by burnaby
I'm creating my first custom widget using the find task. I can retrieve and display the attributes of the returned records but I'm having issues adding graphics to the map. I've created a graphicsLayer called resultsLayer and added it to the map but I keep getting the following error: TypeError: Cannot read property '_graphicsLayer' of undefined. . Any help is appreciated.
showFindResults: function(results){
   console.log("showFindResults");
   var markerSymbol = symbolJsonUtils.fromJson(this.config.symbols.simplemarkersymbol);
   var lineSymbol = symbolJsonUtils.fromJson(this.config.symbols.simplelinesymbol);
   var polygonSymbol = symbolJsonUtils.fromJson(this.config.symbols.simplefillsymbol);
   var resultItems = [];
   var result, attribs;
   array.forEach(results, function (result){
   var graphic = result.feature;
   attribs = result.feature.attributes;
   resultItems.push("Compkey: " + "<b>" + attribs.COMPKEY + "</b><br>");
   resultItems.push("Unitid: " + "<b>" + attribs.UNITID + "</b><br>");
   resultItems.push("Layer Name: " + "<b>" + result.layerName + "</b><br>");
   resultItems.push("<br>");
   switch (graphic.geometry.type)
   case "point":
     graphic.setSymbol(markerSymbol);
  break;
   case "polyline":
    graphic.setSymbol(lineSymbol);
  break;
   case "polygon":
   graphic.setSymbol(polygonSymbol);
  break;
     this.resultsLayer.add(graphic);
     //this.map.graphics.add(graphic);
Outcomes
