locks
1702
05-01-2016 11:14 PM
jayasudha
New Contributor III
Hi
We have bulk DML process that uses ArcSDE 11.1.
I observed dba_lock view in oracle 11gR2 regularly for the following.
select * from dba_lock where session_id=226;
sid      lock_type                                   mode_held        last_convert
226AEShareNone10004355Not Blocking
226PL/SQL User LockExclusiveNone107374226804354Not Blocking
226TORow-X (SX)None6806414218Not Blocking
Various locks are applied and released regularly and after some time, the locks do not change except the LAST_CONVERT value keep on increasing. Then the process hangs.
The log switch activity is at every 15 min.
Please inform your suggestion
jayasudha
New Contributor III
I observed one more thing.
SELECT * FROM sde.table_locks;
214267S05-02-16
218246S05-02-16
The application is not able to release above mentioned locks
