WAB (Dev): Does is support IWA when NOT integrated with AGOL?
1827
04-30-2016 07:07 AM
ThomasColson
MVP Frequent Contributor
From Geoprocessing widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers :
Caution:
Web AppBuilder integrated in ArcGIS Online can access public and secured services from ArcGIS Server. However, secured services do not support ArcGIS Server with Web Tier authentication, such as IWA, PKI, or LDAP authentication. Refer to ArcGIS Online ArcGIS Sever web services for more information."
Could one read between the lines, and assume that since the author DID NOT explicitly say "Integrated with Portal for ArcGIS", that WAB WILL work with secure ArcGIS Server services, specifically, IWA, if the app is registered with PTL and not AGOL?
I'm running into an issue where the GP Widget in WAB(Dev) will validate the URL for an IWA/HTTPS GP Service, but will go no further than that.
ColeAndrews
Occasional Contributor III
Thomas, see bug here, could this be what you're running in to?
http://support.esri.com/en/bugs/nimbus/QlVHLTAwMDA5NDE1Mg==
We attempted using WAB Dev GP widget, but would get a spinning wheel when validating the URL and could not go any further. It was determined by Esri support that the GP widget doesn't support IWA.
