load two widgets at startup
1962
04-28-2016 08:32 AM
NatashaManzuiga
Hi all, I have set the param "openAtStart": true in two widgets and Web Appbuilder only load the first one...
What can I do to run both at startup?
Naty
RobertScheitlin__GISP
Naty,
  The only two themes that support showing more then one widget at startup is the Launchpad theme and the dart theme.
Naty,
NatashaManzuiga
Hi Robert, then I can try opening the second one from the first?
Naty
Natty,
No all the other theme have code set in them to close the open widget before opening another. Now in the foldable them you can set a onscreen widget AND a header controller widget to open at start to technically you can have two widgets set to open at start.
