Synchronize Replica failed Version not found
3755
5
04-27-2016 12:38 PM
el_mehdibayane1
When
I try to Synchronize Changes from the replica someone else made I get the following
error:
Version not found[DBO.Test]
An Invalid SQL statement was used.
Type of Replica : Check out
ArcGIS version 10.2.2
trying to synch on both arc catalogue and arcmap gives the same error
Any solutions
JoeBorgione
First, the routine questions:  what version ArcGIS, what type of Enterprise Geodatabase (Oracle, SQl Server Etc) ?
What type of replication: check out, one way or two way?
How are you performing the sync:  in ArcMap or ArcCatalog?
My guess is the connection you are using points to a version different than the one the Replication is based on.  For example; I replicate using my "Edit" version, not sde.default.
Version 10.0 use Databse Connection Properties:
Version 10.3.1 use  Geodatabse Connection Properties:
el_mehdibayane1
JoeBorgione
It may be a permission issue for you as well;  user dbo owns the version, which sends up a warning for me.  I avoid dbo ownership of anything like the plague.
el_mehdibayane1
So what is the solution now  Thanks again
JoeBorgione
I can only offer a suggestion: if it works then it becomes a solution...
You may need to create a new replica based on the most current data in a version you can use.  I've not used check out replications, only one way and two way.
