How do I split a DEM into 4 quadrants with an 100 meter overlay and export 4 different files?
3230
6
04-27-2016 10:52 AM
MarinaMeter
New Contributor III
Details- I have  USGS DEM (utm 11 NAD 83) and I need to split these into 4 equal quadrants, each with a 100 meter overlap, and export each of these files separately, can this be done? what tools could do this?
Tags (1)
DanPatterson_Retired
so you  want to split it into 4... we will use the clip tool, I am assuming you mixed up East and west
              5,020,000
500,000                   532,100 =>   difference = 32,100  / 2 = 16,050
             4,960,000
N-S difference = 60,000 / 2 = 30,000
bottom left extent
              4,990,100  to give the upper 100 overlap
500,000                  516,150   to give the 100 m overlap
              4, 960,000
repeat for the other 4 quadrants
Clip—Help | ArcGIS for Desktop you just have to do the math by setting the correct extent each time, you can control your bounds.  There are probably fancier ways but this will be the fastest
MarinaMeter
New Contributor III
Im not sure what you mean by control your bounds?? Im new to ESRI my bounds are North 5020,000, South 4960,000, East 500,000, West 532,100. How is this done by setting the extent?
              5,020,000
             4,960,000
bottom left extent
              4, 960,000
MarinaMeter
New Contributor III
Thank you so much Dan for your help on this, i tried both methods and i liked the clip raster function better. I appreciate your help thanks again
marina
you are welcome
SteveLynch
or SplitRaster
