Bad allocation exception
1709
04-27-2016 02:08 AM
AndreasBaier
We are using ArcGis runtime.net 2.6 in our c# application (WPF, .net 4.5.2). The application is running mainly unattended for testing/demo purposes and updating some visuals on a map (circles, lines) on a regular base (e.g. redraw every 2-5 seconds)
We had app crashes coming from the arcgis runtime with the following stacktrace. Somthing internally in arcgis.net is throwing it.
2016-04-19 01:17:16,154 [SvThread] ERROR [(null)] <(null)> - Error in main routine:
exception Details (key=value): (System.Object=) System.Exception: bad allocation
   at RuntimeCoreNet.Interop.HandleException(Boolean retVal)
   at RuntimeCoreNet.CoreGraphicsLayer.AddGraphics(ICoreGeometry[] geometries, ICoreSymbol[] symbols, CoreAttributes[] attributes, CoreGraphicSimpleProperties[] properties, Int32& startId, Int32& endId)
   at RuntimeCoreNet.CoreGraphicsLayerWrapper.AddGraphicsInternal(AdditionInfo additions, SpatialReference mapSR)
   at RuntimeCoreNet.CoreGraphicsLayerWrapper.UpdatePendingGraphics()
   at Esri.ArcGISRuntime.Controls.ViewBase.MapBatchProcess()
   at Esri.ArcGISRuntime.Controls.ViewBase._batchUpdateTimer_Tick(Object sender, Object e)
   at System.Windows.Threading.DispatcherTimer.FireTick(Object unused)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
The question is: what happens here? What does "bad allocation" mean?
It is very hard for me to tell what happens as it is so random - and obviously asyncronous, not directly triggered by code from us. How can I narrow down the root cause?
kind regards
Andreas
