AnsweredAssumed Answered
Geoprocessing Task in ArcGIS API for JavaScript: Creating Buffer around 'map.graphics'
Question asked by jsnyder21 on Apr 22, 2016
Latest reply on Apr 22, 2016 by jsnyder21
I am currently in the process of creating a web application, in which I would like for the user to be able to type in their address, and have this location appear on the map. I have already accomplished this task. Next, I have created a geoprocessing model in ArcMap which should create a buffer around this point, and will find restaurants which intersect this buffer, and display them on the map. The model has 2 parameters, one distance parameter (linear unit), and one input parameter(feature set), which I have set as 'map.graphics' in my script. When I try to run the operation in a browser, i get a generic error: 'init.js:182 Error: Unable to complete operation'. I was wondering if anyone could tell me what they think I am doing wrong. Any help at all would be appreciated. Thanks so much in advance. Here is myJavaScript code:
require([
  "dojo/parser",
  "esri/map",
  "esri/layers/ArcGISDynamicMapServiceLayer",
  "esri/InfoTemplate",
  "esri/dijit/Search",
  "esri/dijit/LayerList",
  "esri/dijit/Scalebar",
  "esri/symbols/SimpleMarkerSymbol",
  "esri/Color",
  "esri/graphic",
  "esri/tasks/Geoprocessor",
  "esri/tasks/LinearUnit",
  "esri/tasks/locator",
                "esri/tasks/FeatureSet",
  "dojo/on",
  "dojo/_base/array",
  "dojo/dom",
  "dijit/registry",
  "dijit/layout/BorderContainer",
  "dijit/layout/ContentPane",
  "dijit/layout/AccordionContainer",
  "dijit/layout/AccordionPane",
  "dijit/layout/TabContainer",
  "dijit/form/Button",
  "dijit/form/Select",
  "dijit/form/HorizontalSlider",
  "dijit/form/HorizontalRule",
  "dijit/form/HorizontalRuleLabels",
  "dojo/domReady!"
  ], function (parser, Map, ArcGISDynamicMapServiceLayer, InfoTemplate, Search, LayerList, Scalebar, SimpleMarkerSymbol, Color, Graphic, Geoprocessor, LinearUnit, Locator, FeatureSet, on, arrayUtils, dom, registry){
  parser.parse();
  var map = new Map("map", { //Create the basemap
  basemap: "streets",
  center: [-77.6559716660883, 38.1850243980318],
  zoom: 11
  var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://gis.spotsylvania.va.us/arcgis/rest/services/SoccerTournamentWebApp/SoccerTournamentMap_Initial/MapServer"); //Request Congressional Districts dynamic map service layer from ArcGIS Server.
  map.addLayer(dynamicMapServiceLayer);
  layers = [ //Create layers for insertion into LayerList constructor
  layer:dynamicMapServiceLayer,
  showSubLayers: true,
  showLegend: true,
  showOpacitySlider: true,
  visibility: true,
  id: "Click arrow to the right to expand the layer list and map legend"
  var onMapLoad = function() {
  var layerList = new LayerList({
  map: map,
  layers: layers
  },"layerlist");
  layerList.startup();
  onMapLoad();
  var scaleBar = new Scalebar({
  map: map,
  attachTo: "bottom-left",
  scalebarStyle: "ruler",
  scalebarUnit: "english"
  var locator = new Locator("http://gis.spotsylvania.va.us/arcgis/rest/services/SoccerTournamentWebApp/AddressLocator/GeocodeServer");
  var s = new Search({
  map: map,
  }, "search");
  s.startup();
  registry.byId("locate").on("click", locate);
  function locate() {
  if(dom.byId("Street").value == "") {
  alert("Make sure that you have filled in all of the text boxes to find your location. Restaurants near you cannot be found unless your current location is known.")
  else if(dom.byId("City").value == "") {
  else if(dom.byId("State").value == "") {
  else if(dom.byId("ZIP").value == "") {
  else {
  map.graphics.clear();
  var address = {"Single Line Input" : dom.byId("Street").value.toString() + "," + " " + dom.byId("City").value.toString() + "," + " " + dom.byId("State").value.toString() + "," + " " + dom.byId("ZIP").value.toString()};
  console.log(address)
  locator.outSpatialReference = map.spatialReference;
  var options = {
  address: address,
  outFields: ["*"]
  locator.addressToLocations(options, showResults);
  function showResults(results) {
     var candidate;
                    var symbol = new SimpleMarkerSymbol();
                      var infoTemplate = new InfoTemplate(
                        "Your Current Location",
                        "Address: ${address}"
                      symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
                      symbol.setColor(new Color([255,0,0,0.75]));
  var geom;
  arrayUtils.every(results, function(candidate) {
    console.log(candidate.score);
    if (candidate.score > 80){
    var attributes = {
    address: candidate.address,
    score: candidate.score
    geom = candidate.location;
    var graphic = new Graphic(geom, symbol,attributes,infoTemplate);
    map.graphics.add(graphic);
    return false;
    else
    return true;
  if ( geom !== undefined ) {
  map.centerAndZoom(geom, 12);
                    registry.byId("findRestaurants").on("click", findRestaurants);
                    function findRestaurants() {
                        var gp = new Geoprocessor("http://gis.spotsylvania.va.us/arcgis/rest/services/SoccerTournamentWebApp/FindRestaurantsNearMe/GPServer/Find%20Restaraunts%20Close%20to%20Me");
                        gp.setOutputSpatialReference({wkid:102100});
                        var distance = dom.byId("distance").value;
                        var distUnit = new LinearUnit();
                        distUnit.distance = distance;
                        distUnit.units = "esriMiles";
                        var inputFeatures = new FeatureSet();
                        var features = [];
                        features.push(map.graphics);
                        console.log(features);
                        inputFeatures.features = features;
                        var params = { "Distance": distUnit, "Feature_Set": features };
  console.log(gp);
                        console.log(params);
                        gp.execute(params, drawRestaurants);
                    function drawRestaurants(results) {
                    var symbol1 = new SimpleMarkerSymbol();
                      var infoTemplate1 = new InfoTemplate(
                        "${Name of Facility}",
                        symbol1.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
                      symbol1.setColor(new Color([0,0,255]));
  var features = results[0].value.features;
                        for (var f=0; f<features.length; f++) {
                            var feature = features[f];
                            feature.setSymbol(symbol1);
                            map.graphics.add(feature);
Outcomes
