Playa
Polygon Centroid: Center of gravity & Inner Centroid
Discussion created by Playa on Apr 18, 2016
Latest reply on Apr 18, 2016 by Dan_Patterson
I thought I'd share the following with the community:
Created on Apr 18, 2016
Centroid
of Polygon
@author: PeterW
import arcpy
from arcpy.arcobjects.geometries import PointGeometry
input_fc = r"E:\Proposals\2016\what3words\Calcs.gdb\ftr_dwellings_zola_tm19"
output_fc = r"E:\Proposals\2016\what3words\Calcs.gdb\Centroids_Test15"
def coord_sys(input_fc):
    projection = arcpy.Describe(input_fc).spatialReference
    return projection
projection = coord_sys(input_fc)
def centroid(input_fc, output_fc):
    with arcpy.da.SearchCursor(input_fc, "SHAPE@XY") as scur:  # @UndefinedVariable
        centroid_coords = []
        for feature in scur:
            centroid_coords.append(feature[0])
    point = arcpy.Point()
    pointGeometryList = []
    for pt in centroid_coords:
        point.X = pt[0]
        point.Y = pt[1]
        pointGeometry = arcpy.PointGeometry(point, projection)
        pointGeometryList.append(pointGeometry)
    arcpy.CopyFeatures_management(pointGeometryList, output_fc)
Centroid: Center of Gravity
Inner Centroid
of Polygon
@author: PeterW
import arcpy
output_fc = r"E:\Proposals\2016\what3words\Calcs.gdb\Centroids_Test7"
    return projection
def inner_centroid(input_fc, output_fc):
    inner_centroid_geom = []
    with arcpy.da.SearchCursor(input_fc, "SHAPE@") as scur:  # @UndefinedVariable
            inner_centroid_pnt = arcpy.PointGeometry(feature[0].labelPoint, projection)
            inner_centroid_geom.append(inner_centroid_pnt)
    arcpy.CopyFeatures_management(inner_centroid_geom, output_fc)
Centroid: Inner Centroid
Outcomes
