Migrate an existing enterprise geodatabase to a new enterprise geodatabase?
2735
04-18-2016 08:19 AM
JamesFitzgerald3
New Contributor III
I have a current SDE using SQL 2008 R2. I want to migrate my current SDE to a new SDE. The new SDE has a different schema. Is there a way I can keep the instance name and database name?
by Anonymous User
Not applicable
Hey James - can you clarify what you're hoping to do? Are you moving your geodatabase to a new SQL Server instance, or are you hoping to move all your data from one geodatabase to another geodatabase in the same SQL Server instance? OR do you just want the data to be owned by a different user/schema, but remain in the same geodatabase?
