AnsweredAssumed Answered
Web AppBuilder attributes
Question asked by jsn on Apr 15, 2016
Latest reply on Jun 11, 2018 by andrescastillo08
Hello everyone,
This question is about how to add logic in ArcGIS Online to fields that are populated by application, not by data entry.
I was able to create in ArcGIS Online a Web Mapping Application that has only one layer. The layer is a feature service pointing to SDE in a versioned environment.  The layer is a polygon.
The ArcGIS Online web mapping application works fine. It  allows to digitize a new feature polygon and populate its attributes.
My question is about how pre-populate some  attributes with default values such as:
  • Date Created, Date when record was created
  • CreatedBy, Editors User ID
  • DateModified, Date when record was modified for the last time
  • ModifiedBy, Editors User ID
  • PrimaryKeyID, populated with a sequential number, obtained from a sequencer in Oracle
  • Other fields  like municipality or commission district that are populated with the value of the Municipality or Commission district where this polygon intersects
For desktop applications I solved this issue creating an ArcMap Add-In.
In the old Web ADF I solved this issue using the event:
  • Protected Sub EditorTask1_PostToolExecute(ByVal sender As Object, ByVal editorToolEventArgs As EditorToolEventArgs)  Handles EditorTask1.PostToolExecute
I would like to know how to do that with Web AppBuilder
Outcomes
