Print showAttribution not working
2770
04-12-2016 10:50 AM
AlexGole
Occasional Contributor II
Hi all,
I am trying to use Print template showAttribution option but cant make it work for some reasons. I dont want to show the map sources because it gets cut off sometimes when printing. Any idea?
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8">
    <title></title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; padding: 0 0 5px 0; text-align: center; }
      .shadow {
        -moz-box-shadow: 0 0 5px #888;
        -webkit-box-shadow: 0 0 5px #888;
      #map{ margin: 0; padding: 0; }
      #feedback {
        background: #fff;
        border: 2px solid #666;
        border-radius: 5px;
        bottom: 20px;
        color: #666;
        font-family: arial;
        height: auto;
        left: 20px;
        margin: 5px;
        padding: 10px;
        position: absolute;
        width: 300px;
        z-index: 40;
      #feedback a {
        border-bottom: 1px solid #888;
        color: #666;
        text-decoration: none;
      #feedback a:hover, #feedback a:active, #feedback a:visited {
        border: none;
        color: #666;
      #note { padding: 0 0 10px 0; }
      #info { padding: 10px 0 0 0; }
    </style>
    <script src="https://js.arcgis.com/3.16/"></script>
    <script>
      var app = {};
      require([
        "esri/arcgis/utils", "esri/dijit/Print",
        "esri/tasks/PrintTemplate", "esri/config",
        "dojo/_base/array", "dojo/dom", "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        arcgisUtils, Print,
        PrintTemplate, esriConfig,
        arrayUtils, dom, parser
        parser.parse();
        app.webmapId = "8315cf7d20f0484e869c4791f70f4f15";
        app.printUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%...";
        esriConfig.defaults.io.proxyUrl = "/proxy/";
        var webmap = arcgisUtils.createMap(app.webmapId, "map", {
          mapOptions: {
            center: [-85.673, 38.21],
            zoom: 10
        webmap.then(function(resp) {
          app.mapInfo = resp.itemInfo.item;
          app.map = resp.map;
          createPrintDijit(app.mapInfo.title);
        function createPrintDijit(printTitle) {
          var layoutTemplate, templateNames, mapOnlyIndex, templates;
          // create an array of objects that will be used to create print templates
          var layouts = [{
            name: "Letter ANSI A Landscape",
            label: "Landscape (PDF)",
            format: "pdf",
            options: {
              legendLayers: [], // empty array means no legend
              scalebarUnit: "Miles",
              titleText: printTitle + ", Landscape PDF"
            name: "Letter ANSI A Portrait",
            label: "Portrait (Image)",
            format: "jpg",
            options:  {
              legendLayers: [],
              titleText: printTitle + ", Portrait JPG"
          // create the print templates
          var templates = arrayUtils.map(layouts, function(lo) {
            var t = new PrintTemplate();
            t.layout = lo.name;
            t.showAttribution = false;
            t.label = lo.label;
            t.format = lo.format;
            t.layoutOptions = lo.options;
            return t;
          app.printer = new Print({
            map: app.map,
            templates: templates,
            url: app.printUrl
          }, dom.byId("print_button"));
          app.printer.startup();
    </script>
  </head>
  <body class="tundra">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline',gutters:false"
         style="width: 100%; height: 100%; margin: 0;">
      <div id="map"
           data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'center'">
        <div id="feedback">
          <h3>
            ArcGIS.com Webmap and the Print Dijit
          </h3>
          <div id="info">
            <div id="note">
              Note:  This sample uses an ArcGIS Server version 10.1 export web map task.
            </div>
            <div id="print_button"></div>
            <div id="info">
              The map is <a href="https://developers.arcgis.com/javascript/jsapi/esri.arcgis.utils-amd.html#createmap">created from an ArcGIS.com webmap</a> and
              <a href="https://developers.arcgis.com/javascript/jsapi/printtemplate-amd.html">print templates</a> are
              created manually. Refer to the documentation for more print template options (output formats, additional layouts, etc.).
            </div>
          </div>
        </div>
      </div>
    </div>
  </body>
</html>
YueWu1
by Esri Regular Contributor
Hi Alex,
I tested this from my side and the issue I believe is that Server REST endpoint doesn't honor this parameter: showAttribution that generates from JavaScript API side.
Checked the REST API online documentation ArcGIS REST API​, but I didn't find any reference point to showAttribution, But when you take a look about the request, you can see WebJSON contains "showAttribution"
"mapOptions": {
        "showAttribution": false,
I have already logged an enhancement for the ArcGIS Server [ENH-000095722 showAttribution value doesn't honor in Export Web Map Task in REST]
YueWu1
Hi Alex,
"mapOptions": {
AlexGole
Interesting! Thank you for sharing.
RobertScheitlin__GISP
What I have done is to remove the dynamic element for map attribution in the layouts for the print task when I setup my own custom print service:
Tutorial: Publishing additional services for printing—Documentation | ArcGIS for Server
Supporting High-Quality Printing in Web Applications with ArcGIS 10.1 for Server | Esri Video
Noah-Sager
Also see this post https://community.esri.com/message/721690 for more information on this topic.
