JavaScript 4.0 Label Points with an Attribute value ..?
3283
04-06-2016 02:17 AM
JawadhHabeeb1
I am using JavaScript 4.0 for creating an Application, Is there a way to Give Labels on Point Features instead of basic Symbology, ..?
The Labels Needs to come from a Particular Value in the Attribute Table.
Regards,
Jawadh
KristianEkenes
Labelling does work in beta 3. The issue Marc is referring to is slightly different. It doesn't refer to data attributes. See this example of how you can add labels in 3D - Symbol layers outline
This uses polygons, but the same principles should apply to points. Here's the code for the sample: esri-js-samples/symbol-layer-outline.html at master · ekenes/esri-js-samples · GitHub
MarcBate
Occasional Contributor II
It doesn't work with 4 beta 3.  See my post
LabelClass or TextSymbol in v4 beta 3?
Esri, please add to known issues with beta 3
KristianEkenes
JawadhHabeeb1
Now I am stuck with Displaying it in 2D now .. my application is both in 2D and 3D ..
The 3D label works very well
I think I am stuck here
var labelClass = new LabelClass({
  labelExpressionInfo: {
  value: "{Some_value}"
symbol: new LabelSymbol3D({                                               ----> can these symbols be in 2D mapView also ..?
        symbolLayers: [new TextSymbol3DLayer({                   ----->
          material: { color: [49,163,84] },
KristianEkenes
No. Any symbol with "3D" in its name cannot be used in MapView. MapView labels aren't supported in beta 3.
