ebrown123
WMS Mappings
Discussion created by ebrown123 on Apr 1, 2016
Does anyone know where the parameter is grabbed from to set the values for the WMS xml? Example, the value is pulled in for WMS_Capabilities, and a xlink:href=, and if you are on an internal endpoint and you select a mapservice and click WMS, the mappings reflect that server. If you select the same service on an external endpoint then the WMS service reflects the external server, so I know that the values are not static but dynamic.
So I am wondering in what file is that value being pulled from?
Any ideas?
Thanks!
Outcomes
