Calculating acres from Edit Widget pop-up window
2635
04-01-2016 11:45 AM
RobertMueller_Jr1
New Contributor III
I am trying to allow a user to calculate geometry for a predefined field from the Edit widget pop-up window using the ESRI JS geometryEngine. So far I've added a button to the Edit widget pop-up (in place of the close button), and assigning a variable to the selected features. However, Firebug tells me there is an error on this line in the geometryengine.js
                    var CalcAcres=geometryEngine.geodesicArea(SelectedPoly, "acres")
Anyone have an idea on what's going on? My current thinking is that I'm doing to much in the "addButtonToInspector" and need to move the calculation somewhere outside this function
  _addButtonToInspector: function() {
        /*var closeButton = new Button({
          label: esriBundle.common.close,
          "class": " atiButton closeButton"
        }, html.create("div"));
        //Swapping out the CalcAcresButton for the "close" button
        var CalcAcresButton = new Button({
          label: "Calculate Acres",
          "class": " atiButton CalcAcresButton"
        html.place(CalcAcresButton.domNode,
                   this.editor.attributeInspector.deleteBtn.domNode,
                   "after");
        this.own(on(CalcAcresButton, 'click', lang.hitch(this, function() {
                //Get Selected polygon
              var SelectedPoly = this.map.infoWindow.getSelectedFeature();
              //Calculate the acreage, store in avariable
              //Either "acres" or 109403
              var CalcAcres=geometryEngine.geodesicArea(SelectedPoly, "acres");
              //setting the value for the "Acres" field for with the calculated value
              featureLayer.setAttributes({"Acres":CalcAcres});
             //Applying the edits to the featurelayer
             this.featureLayer.applyEdits(null, [featureLayer], null);
Tags (1)
