When you have dual carriageways or medians which do not have any addressing associated with the street segment, what is the best values (red boxes) to use to indicated no address (address range) and such, these segments will not show up in manual geocoding matching as segments meeting address requirements.
For Esri’s geocoder, should the values be 0, -1, or some very large number beyond the normal address ranges for our municipality?
Is seems like if we use zero, those streets show up as candidates while manually matching unmatched addresses, that does not seem correct. The geocoding engine should be ignoring those segments.”
