Help with Creating a map on top of Esri's Basemap Gallery
2659
6
03-30-2016 09:12 AM
RichardLafleur
I need help getting the following map/code to show up, but have the map gallery as the basemap.
My code
arcgisUtils.createMap("511bd0e84f1441edb7bf55167ecddec2", "map").then(function (response) {
              //update the app
              dom.byId("title").innerHTML = response.itemInfo.item.title;
              dom.byId("subtitle").innerHTML = response.itemInfo.item.snippet;
              map = response.map;
              //add the scalebar
              scalebar = new Scalebar({
                map: map,
                scalebarUnit: "english"
              overviewMapDijit = new OverviewMap({
                map: map,
                visible: true
              overviewMapDijit.startup();
              //add the legend. Note that we use the utility method getLegendLayers to get
              //the layers to display in the legend from the createMap response.
              var legendLayers = arcgisUtils.getLegendLayers(response);
              legendDijit = new Legend({
                map: map,
                layerInfos: legendLayers
              }, "legend");
              legendDijit.startup();
the Map gallery
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title></title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
  <style>
    html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    #map{
      padding:0;
  </style>
  <script src="https://js.arcgis.com/3.16/"></script>
  <script>
    var map;
    require([
      "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
      "dojo/parser",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
      "dojo/domReady!"
    ], function(
      Map, BasemapGallery, arcgisUtils,
      parser
      parser.parse();
      map = new Map("map", {
        basemap: "topo",
        center: [-105.255, 40.022],
        zoom: 13
      //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
      var basemapGallery = new BasemapGallery({
        showArcGISBasemaps: true,
        map: map
      }, "basemapGallery");
      basemapGallery.startup();
      basemapGallery.on("error", function(msg) {
        console.log("basemap gallery error:  ", msg);
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer"
       data-dojo-props="design:'headline', gutters:false"
       style="width:100%;height:100%;margin:0;">
    <div id="map"
         data-dojo-type="dijit/layout/ContentPane"
         data-dojo-props="region:'center'"
         style="padding:0;">
      <div style="position:absolute; right:20px; top:10px; z-Index:999;">
        <div data-dojo-type="dijit/TitlePane"
             data-dojo-props="title:'Switch Basemap', closable:false, open:false">
          <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
            <div id="basemapGallery"></div>
          </div>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
Also,as you can see in my code i have a legend, scalebar, and overview map that i need as well. Can anyone help with this i dont really care what the layout looks like just as long as my map shows up on top of the basmap gallery and i can change the basemap and yet have my data stay put.
RichardLafleur
can someone please help with this, or at least direct me to the correct result.
AdrianWelsh
MVP Honored Contributor
Richard,
Is there any error being thrown with the basemap error message?
RichardLafleur
I think i am placing my code in the wrong place and might be missing some code, cause when i run it everything disappears.
RichardLafleur
Here is an update of what i have been able to figure out, what i can't get now is the "switch basemap" drop down to actually switch the basemap.
<!DOCTYPE html>
<html>
  <head>
    <title>Create web map from id</title>
    <link rel="stylesheet" href="css/layout.css">
    <style>
    #map{
      padding:0;
  </style>
    <script>
    var map;
      require([
        "dojo/parser",
        "dojo/ready",
        "dijit/TitlePane",
        "dojo/dom",
        "esri/map",
        "esri/dijit/Legend",
        "esri/dijit/Scalebar",
        "esri/dijit/OverviewMap",
        "dojo/domReady!"
      ], function(
        parser,
        ready,
        BorderContainer,
        ContentPane,
        TitlePane,
        dom,
        Map,
        BasemapGallery,
        arcgisUtils,
        Legend,
        Scalebar,
        OverviewMap
        ready(function(){
        parser.parse();
//if accessing webmap from a portal outside of ArcGIS Online, uncomment and replace path with portal URL
       //arcgisUtils.arcgisUrl = "https://pathto/portal/sharing/content/items";
        arcgisUtils.createMap("511bd0e84f1441edb7bf55167ecddec2", "map").then(function(response){
          //update the app
          var map = response.map;
          //add the scalebar
          var scalebar = new Scalebar({
            map: map,
          var legendDijit = new Legend({
            map: map,
          },"legend");
          var overviewMapDijit = new OverviewMap({
          map: map,
          visible: true,
          attachTo: "bottom-right"
        map: map
    </script>
  </head>
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
      <div id="header" class="shadow roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
        <div id="title"></div>
        <div id="subtitle"></div>
      </div>
      <div id="map"
         style="padding:0;">
          </div>
        </div>
      </div>
      </div>
      <div id="rightPane" class="roundedCorners shadow" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" >
        <div id="legend"></div>
      </div>
    </div>
  </body>
</html>
RichardLafleur
if you cant get your code the code to work, i am having to building this in a virtual machine, and then within esri's sandbox
located here ArcGIS API for JavaScript Sandbox
AdrianWelsh
Richard,
I really am at a loss. I tried toying around with this in the sandbox and could not get the basemap to change. I feel like it has something to do with this line:
...but I really don't know.
Just some advice, it might help to put your code in the code editor (click on "Usa advanced editor" > double arrows > Syntax > Javascript)
