I created a tile package using ArcGIS desktop 10.3.1. I then uploaded that tile package to AGOL using the add item interface in My Content. This tiled layer works fine. I then created a hosted feature layer from the same dataset that I tiled. This layer also works fine. When I add my tiled layer to the arcgis.com map and open the enable pop-ups menu I select "Choose from my items" and select the hosted feature layer that I created I get the message "The layer referenced by MyHostedFeatureLayer is not available."
I have succesfully enabled pop-ups on tiled layers using URL's from ArcGIS server services. Is it possible to enable pop-ups on a tiled layer with a feature layer hosted on AGOL? I get the "The layer referenced by MyHostedFeatureLayer is not available," message from all items hosted on AGOL.
The two layers in question are:
https://ufl.maps.arcgis.com/home/item.html?id=fe4bbd5c01d142b898af49ec2d73f8b7
https://ufl.maps.arcgis.com/home/item.html?id=1a23efe13afd49eea82b1f288279547d
