I have a column chart that shows up with values from my Field Attributes on the Y-Axis every time I click in the pop-up. Is there a way to display the X-Axis labels or would I have to go around and create a chart in my code? If that is the case, how to I link them? Thanks in advance!
var WPRinpopup = new PopupTemplate({
title: "{NAME} Water Planning Region Average Estimated Precipitation",
description: "Graph below depicts avereage estimated yearly values of Precipitation in {NAME} Water Planning Region. <
fieldInfos: [
{fieldName: "F2004", label: "2004", },
{fieldName: "F2005", label: "2005", },
{fieldName: "F2006", label: "2006", },
{fieldName: "F2007", label: "2007", },
{fieldName: "F2008", label: "2008", },
{fieldName: "F2009", label: "2009", },
{fieldName: "F2010", label: "2010", },
{fieldName: "F2011", label: "2011", },
{fieldName: "F2012", label: "2012", },
{fieldName: "F2013", label: "2013", }
mediaInfos:[{
caption: "Maximize Popup Window to view Graph.",
type: "columnchart",
value:{
theme: "Julie",
fields:[ "F2004", "F2005", "F2006", "F2007", "F2008",
"F2009", "F2010", "F2011", "F2012", "F2013"]
