how to add privileges
3230
03-23-2016 08:19 AM
zachzelefsky
I am working on mapping leads for my company and wanted to do analysis after mapping. How can I add the analysis feature when no organization administrator was selected and we believe to be using the only known account?
Any help would be appreciated.
Tags (1)
RebeccaStrauch__GISP
Are you needing to ad an administrator for your company's ArcGIS Online account?  Are you just needing to share a map posted?  Are you wanting to allow editing for the map (if so, you can edit the map document (go to the details page) and at the bottom there is a place to turn editing on....the you need to share it as needed).
You should probably provide a little more information re: this is the ArcGIS Online/Portal or ArcGIS Server, or using one of the APIs (javascript) or what else you may be developing in.
BTW - you currently have this in the "Web Developers" space.  You can try Moving Content​ to another GeoNet Community Structure​ space, if it isn't web development.
