Map Service Will Not Publish!
2315
6
03-22-2016 07:20 PM
DaveTenney
Occasional Contributor III
Running 10.2.2
  i have have been publishing services all day to Server Machine A and then from Machine A to Server Machine B. No all of a sudden i get that dreaded ERROR 001639..."Packaging succeeded, but publishing failed. ERROR 001369: Failed to create the service."
   i did look at the logs for the publishing tools and noticed that it threw out and error for all the layers associated with Imagery as "invalid" im not sure sure what is meant by invalid.
dave
DaveTenney
found the problem...
   somehow, most likely me , one of the data source paths for imagery got changed and caused the publishing failure.
found the issue and fixed...service is now published!
dave
AdrianWelsh
MVP Honored Contributor
Hi Dave,
When you are publishing your map, I presume it is from ArcMap? Also, when publishing, do you have a basemap loaded into your table of contents? If you are not wanting to publish this basemap (and likely you do not want to), then remove the basemap before publishing (don't just turn it off, remove it from your TOC).
DaveTenney
yes i am publishing in ArcMAP.
AdrianWelsh
Dave, is there a chance that you have a basemap in your table of contents (even unchecked) when you are publishing?
DaveTenney
no basemap, the mxd had already been published to one server instance(machine A) and I'm now trying to publish to another instance(Machine B)
    I have all the data in place on both machines, data shares set up, data stores set up...
here is a screenshot of the log, it keeps pointing back at imagery layers as invalid, maybe this will help(see attachment)
DaveTenney
dave
AdrianWelsh
That's always a huge relief! Glad it is working for you!
