searchcursor to compare records
3842
03-22-2016 07:42 AM
BrianLomas
Occasional Contributor III
I'm new to python so forgive me if this seems like an easy question... I want to compare fields of an mdb and a FC to identify inconsistencies. Also, the field names do not match. So, I have a script using a searchcursor and lists. Right now the script runs but it only seems to run on the first field and I need it to loop through 12 total. Any ideas on how to keep the loop running through all the fields?
from time import strftime
print "Start script: " + strftime("%Y-%m-%d %H:%M:%S")
import arcpy
sourceFC = "M:\...\January2015Ownership"
sourceFieldsList = ["PARCEL_","SITUS", "CURRENT_OWNER", "CO_OWNER", "OWNER_MAILADDR", "OWNER_CITY_STATE", "OWNER_ZIPCODE",  "TAX_DISTRICT", "TAX_CODE", "SEC", "TOWNSHIP", "RANGE", "LEGAL"]
# Use list comprehension to build a dictionary from a da SearchCursor
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sourceFC, sourceFieldsList)}
updateFC = "M:\...\TaxParcel_COPY"
updateFieldsList = ['PARCELID','SITEADDRESS','OWNERNME1', 'OWNERNME2', 'PSTLADDRESS', 'PSTLCITY', 'ZIPCODE', 'TAX_DIST',  'TAX_CODE', 'SEC', 'TWN', 'RGE', 'PRPRTYDSCRP']
with arcpy.da.SearchCursor(updateFC, updateFieldsList) as originalRows:
        for originalRow in originalRows:
            # store the Join value of the row being original in a keyValue variable
            keyValue = originalRow[0]
            # verify that the keyValue is in the Dictionary
            if keyValue in valueDict:
                   for n in range (1,len(sourceFieldsList)):
                        if originalRow != valueDict[keyValue][n-1]:
                            print(str(keyValue) + ' was Changed in field "' + sourceFieldsList + '"')
                            break
            else:
                print(str(keyValue) + ' check')
                break
del valueDict
print "Finished script: " + strftime("%Y-%m-%d %H:%M:%S")
BrianLomas
Well, I knew it had to be something easy. I removed the "break" after the if and else statement and it seems to run on all the fields now. I still have a little work to do on the script but I appreciate the help and fast responses.
AdrianWelsh
MVP Honored Contributor
Hi Brian,
It looks like it may be an issue with your text string for updateFC. Try putting in an "r" at the beginning of it.
updateFC = r'M:\BrianLomas\Python Scripts\ParcelPracticeCopies\ParcelPythonCOPIES.gdb\TaxParcel_COPY'
See this thread/poll on python naming string conventions:
BrianLomas
After changing the path names to raw path strings, I am still getting the same issue. The script will run but it seems to only go through the first field when I know there are more inconsistencies in other fields. I think the issue might be in the loop.
DanPatterson_Retired
In fact, both feature classes should use raw notation (ie line 7)
BrianLomas
