AnsweredAssumed Answered
Extending standard widget for Operations Dashboard using JavaScript
Question asked by d.mastesri-de-esridist Employee on Mar 18, 2016
We been working on developing extensions for Operations Dashboard 10.3.2 with JavaScript which we have found to be generally straight-forward for simple widgets built from scratch following the samples on gitHub. A client has asked us to extend the functionality of the standard widget Bar Diagram and to do so, we want to use the code from the Bar Diagram widget as a base. However since the current version of OpDashboard is built with the ArcGIS Runtime SDK for WPF, we do not have access to the JavaScript widget’s code. The idea is to use the widget right away in the browser version of OpDashboard with Portal for ArcGIS 10.4 and also in the next release (OpD 10.4?) in the coming months. We want to avoid trying to “reinvent the wheel” by writing a new widget from scratch to do almost the same thing as the Bar Diagram widget already does and we need a quick solution to be able to deploy mid-April.
The question is, is there a recommended workflow for extending standard widgets using JavaScript?
Thank you in advance for your help,
Daniel
Outcomes
