I use bower build for some project, and since 3.15 the new vector tile process is using Map Box vector tile project inside ArcGIS API, its located in layers/vector-tile.js.
When I try to integrate this resource in my build, I have a dojo build error :
Missing include module for layer missing: js/layers/vector-tile.js layer: dojo/dojo
Maybe some mapbox-gl prefix are not bound or something like that. Did someone experience that ?
Have you ever found a solution for this?
We're currently having the exact same issue while migrating from 3.15 to 3.17, and judging by what i found (or didn't find...) on the whole Internet, it seems like we're the only ones having this issue...
If you have any updates, please share 🙂
Hi David,
Sorry to reply so late, there is 2 options :
1- tell dojo build system to not include vector-tile
2- build a separate layer (as esri does in 3.18)
The best option is definitely to upgrade to 3.18 and use the last update of jsapi-resources via github
Tony
