where to add minZoom and maxZoom options in TAB Theme?
2756
8
03-17-2016 03:13 PM
WilsonLee
Hi All,
I've downloaded the codes for the TAB THEME map and I would like to update the mapOption with setting minZoom and maxZoom properties. But i couldn't find the core.js or main.js in the folder (see attached screenshot), where do I add the min/maxZoom options to?
Please help.
thanks,
Wilson
(i'm looking for this piece of script and try to insert min/maxzoom options)
var mapDeferred = esri.arcgis.utils.createMap(WEBMAP_ID, "map", {
mapOptions: {
slider: false,
wrapAround180:false
minZoom: 10,
maxZoom: 12
Tags (1)
RobertScheitlin__GISP
Wilson,
  You add those to the mapOtpions object in the main config.json (line 23 below):
"map": {
    "3D": false,
    "2D": true,
    "position": {
      "left": 0,
      "top": 40,
      "right": 0,
      "bottom": 0
    "itemId": "your item id",
    "mapOptions": {
      "extent": {
        "xmin": -9588945.63048467,
        "ymin": 3961163.9078186783,
        "xmax": -9521681.045593806,
        "ymax": 4027893.4335115473,
        "spatialReference": {
          "wkid": 102100
      "showAttribution": false,
      "logo": false,
      "maxZoom": xxxx,
WilsonLee
Hi Robert,
Thanks, I found the the config.json and add the min/max options. But it didnt work. My map can stil zoom in and out to all levels.
do you have any ideas what's going on?
      "mapOptions":{
         "extent":{
            "xmin":6070767.733441663,
            "ymin":1977523.8093268164,
            "xmax":6083470.535432744,
            "ymax":1986454.2640599394,
            "spatialReference":{
               "wkid":102643,
               "latestWkid":2227
   "minZoom": 13,
   "maxZoom": 19,
      "id":"map",
thanks again : )
Wilson
Wilson,
  You have those properties outside the MapOptions object.
This should be correct:
    "mapOptions":{
         "extent":{
               "wkid":102643,
               "latestWkid":2227
         "minZoom": 13,
         "maxZoom": 19
WilsonLee
Hi Robert,
I placed the min/maxzoom within the MAPSOPTIONS now and it's still not working:
"mapOptions":{
         "extent":{
               "wkid":102643,
               "latestWkid":2227
  "minZoom": 15,
  "maxZoom": 18
Wilson,
  It works perfectly for me maybe you are still not putting it in the right place. If you are working on adding this to a spcific app you have already created the add the code to [install dir]\server\apps\[app #]\config.json.
Here is the whole map object this time:
"map": {
    "3D": false,
    "2D": true,
    "position": {
      "left": 0,
      "top": 40,
      "right": 0,
      "bottom": 0
    "itemId": "xxxxxxxxxxxxxxxxxxxxxxxxx",
    "mapOptions": {
      "extent": {
        "type": "extent",
        "xmin": -9612248.7868645,
        "ymin": 3963609.132773641,
        "xmax": -9499359.691251043,
        "ymax": 4030413.4467841494,
          "wkid": 102100
      "minZoom": 15,
      "maxZoom": 18
    "id": "map",
    "portalUrl": "http://xxxxxx.maps.arcgis.com/"
WilsonLee
my codes are same as yours. I check all the config.json files and only the one at top level (index.html level)  has the "mapoptions".
   "map":{
      "3D":false,
      "2D":true,
      "position":{
         "top":44,
         "right":0,
         "bottom":24,
         "left":55
      "itemId":"???????",
      "mapOptions":{
         "extent":{
               "wkid":102643,
               "latestWkid":2227
  "minZoom": 17,
  "maxZoom": 20
      "id":"map",
      "portalUrl":"https://????.maps.arcgis.com"
Wilson,
  As I mentioned it worked fine for me. Are you restarting your wab app and clearing your browser cache?
WilsonLee
yes, i did
anyway, thank you for your help. I really appreciate it
