Having trouble configuiring Shortlist Story Map: Error WebMapID is not defined
2634
03-18-2016 12:50 PM
TravisGallo
I am trying to configure my Shortlist Story Map (http://arcg.is/1LUXwIY ) with our organizations website. I am just getting a spinning loading circle and the map never loads. I have configured the index.html page with my Webmap ID, copied the sample template for my .csv file and have removed any special characters in that file. I  get the following errors:
webmapID is not defined.tiff
Thanks in advance for your help!
TravisGallo
I sort of figured this out. I downloaded a new template and put in my WebID and now it works. Maybe I tinkered with the original index file too much while trying to figure it out. Thanks for your help.
Travis
RupertEssinger
Hi Travis. that link you posted is a Story Map Series app not a Story Map Shortlist app.
I found your publicly shared web map in ArcGIS Onlline:
http://www.arcgis.com/home/webmap/viewer.html?webmap=13dd36f4661e4d388833f57f102a56a0
And it draws OK in our test Story Map Shortlist instance:
http://storymaps.esri.com/templates/shortlist/?webmap=13dd36f4661e4d388833f57f102a56a0&DETAILS_PANEL...
Have you put the Shortlist code onto a web server or folder in a public website or hosting service? It should work if you put the ID of the web map into the Index.html file.
I suspect you are perhaps putting the ID of that Story Map Series story map app into the Index.html file, not the ID of a web map.
Rupert
TravisGallo
Hi Rupert, thank you for your response. Yes, we have it at a public site - Shortlist
Below is the index file where I believe i have the right ID.
Thanks again for your help!
Travis
<!DOCTYPE html>
<html>
  <head>
  <title>Shortlist</title>
  <meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1">
  <meta name="apple-mobile-web-app-capable" content="yes">
  <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
  <link type="image/ico" rel="shortcut icon" href="https://community.esri.com//resources.esri.com/favicon.ico">
  <link type="image/ico" rel="icon"  href="https://community.esri.com//resources.esri.com/favicon.ico">
  To correctly reference your application in search engine:
  - create and fill out extensively an ArcGIS.com item that link to your final application
  - edit the following four tags as well as the upper title tag on line 4
  <meta name="description" content="This story map was created with the Esri Story Map Shortlist application.">
  <!-- Facebook sharing -->
  <meta property="og:type" content="article"/>
  <meta property="og:title" content="Story Map Shortlist"/>
  <meta property="og:description" content="This story map was created with the Esri Story Map Shortlist application."/>
  <meta property="og:image" content="resources/images/esri-globe.png">
  <script type="text/javascript">
  var version = '1.4.7';
  // Application configuration
  var WEBMAP_ID = “13dd36f4661e4d388833f57f102a56a0";
  var BOOKMARKS_ALIAS = "Zoom";
  var COLOR_ORDER = "green,red,blue,purple,black"; // will only use as many colors as you have tabs
  var DETAILS_PANEL = false; // specifies whether or not popups have a link to a separate Details panel
  // Specify point feature layers on your map that do NOT define a tab in the Shortlist.
  // These point layers will be displayed as supporting layers.
  // If there's more than one layer, use the "|" character as delimiter
  var POINT_LAYERS_NOT_TO_BE_SHOWN_AS_TABS = "";
  // Specify supporting feature layers in your map that will be clickable in the Shortlist.
  // These layers must use the Shortlist attribute schema for their popups to appear.
  var SUPPORTING_LAYERS_THAT_ARE_CLICKABLE = "";
  // Location button that locates user (on supported browsers)
  var GEOLOCATOR = false;
  // If the tabs are defined using a single layer, you can optionally use these parameters to
  // override the tab order and names defined in that layer without editing the layer.
  // If you specify TAB_NAMES: a) all tabs must be included in TAB_NAMES, whether or not
  // you want to rename them, b) TAB_ORDER must be specified too,
  // c) TAB_NAMES order must correspond with TAB_ORDER. For example:
  // var TAB_ORDER = ['Design', 'Fun', 'Food'];
  // var TAB_NAMES = [
  // {'Design': 'Design'},
  // {'Fun': 'Activities'},
  // {'Food': 'Snacks'}
  var TAB_ORDER = [];
  var TAB_NAMES = [];
  // Optionally to be able to use the webmap URL parameter, configure here the list of webmap authors
  // whose webmaps are allowed to be viewed by this Shortlist deployment
  // This is the ArcGIS Online username of the webmap owner (e.g. ["user1"], ["user1", "user2"])
  var AUTHORIZED_OWNERS = [];
  // Edit to use Portal for ArcGIS
  var DEFAULT_SHARING_URL = "";
  //"http://www.example.com/arcgis/sharing/content/items";
  // Note:  If using a proxy server (required for remote CSV access),
  //        you'll need to provide a valid proxy server url.
  var DEFAULT_PROXY_URL = "";
  //"http://www.example.com/arcgis/sharing/proxy";
  </script>
  <link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.14/esri/css/esri.css" />
  <link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.14/dijit/themes/claro/claro.css">
  <link rel="stylesheet" type="text/css" href="lib/colorbox/colorbox.css">
  <link rel="stylesheet" type="text/css" href="lib/idangerous.swiper.css">
  <link rel="stylesheet" type="text/css" href="app/css/style.css">
  <link rel="stylesheet" type="text/css" href="app/css/responsive.css">
  <!--[if lt IE 9]>
  <link rel="stylesheet" type="text/css" href="app/css/ie8-and-down.css" />
  <![endif]-->
  </head>
  <body class="claro">
  <!-- Header Section-->
  <div id="header">
  <div id="headerText">
  <h1 id="title" tabindex="0"></h1>
  <h2 id="subtitle" ></h2>
  </div>
  <div id="logoArea">
  <div id="social">
  <span class="headerLink" tabindex="-1">
  <a id="msLink" tabindex="-1" href="http://storymaps.arcgis.com" target="_blank">A story map</a>
  </span>
  <i tabindex="-1" class="shareIcon share_facebook socialIcon-facebook-squared-1"></i>
  <i tabindex="-1" class="socialIcon-twitter-1 shareIcon share_twitter"></i>
  <i tabindex="-1" class="socialIcon-link shareIcon share_bitly" id="bitlyIcon" title="Get a short link to the application"></i>
  <div class="popover fade left in" style="display: none;">
  <div class="arrow"></div>
  <div class="popover-content" id="bitlyContent">
  <div style="width:150px; height:30px">
  <input id="bitlyInput" type="text" value="" style="width: 150px;">
  </div>
  </div>
  </div>
  </div>
  <div tabindex="-1" id="logo">
  <a tabindex="-1"  id="logoLink" href="http://www.esri.com" target="_blank">
  <img tabindex="-1" id="logoImg" src="resources/images/esri-logo-white.png" alt="Esri - Home">
  </a>
  </div>
  </div>
  </div>
  <div id="mobileTitlePage"></div>
  <div id="mainWindow">
  <div id="divStrip">
  <div id="tabs"></div>
  <div id="bookmarksCon">
  <div id="bookmarksToggle"> <!--tabindex="0"-->
  <p id="bookmarksTogText"></p>
  </div>
  <div id="bookmarksDiv">
  </div>
  </div>
  </div>
  <div id="mobileBookmarksCon">
  <div id="mobileBookmarksToggle"><p id="mobileBookmarksTogText"></p></div>
  <div id="mobileBookmarksDiv"></div>
  </div>
  <div id="paneLeft">
  <ul id="myList" class="tilelist"></ul>
  <div class="noFeature">
  <span class="noFeatureText">
  </span>
  </div>
  </div>
  <div id="map" tabindex="-1" aria-label="This is a nice map that shows cool things.">
  <div id="zoomToggle">
  <div id="zoomIn">+</div>
  <div id="zoomExtent">
  <img id="zoomExtentImg" src="resources/images/ZoomHome.png">
  </div>
  <div id="zoomOut">-</div>
  <div id="locateButton">
  <img id="locateImage" src="resources/images/locateButton.png">
  </div>
  </div><!--?zoomToggle-->
  <div id="hoverInfo"></div>
  </div>
  <div id="mobileThemeBar">
  <div id="navThemeLeft">
  <span class='icon-arrow-left'></span>
  </div>
  <div id="navThemeRight">
  <span class='icon-arrow-right'></span>
  </div>
  <div class="swiper-container">
    <div class="swiper-wrapper"></div>
  </div>
  <div id='returnIcon'>
  <i class='icon-list'></i>
  </div>
  <div id="returnHiddenBar"></div>
  <div id="centerMapIconContainer">
  <div id='centerMapIcon'>
  <i class='icon-contract'></i>
  </div>
  </div>
  </div>
  <div id="mobilePaneList">
  <ul id="mobileList" class="mobileTileList"></ul>
  <!--There are no features within the current map extent.
  Click on the home button to return to the initial extent.-->
  </span>
  </div>
  </div>
  <div id="mobileFeature">
  </div>
  </div>
  <div id="mobileSupportedLayersView"></div>
  <div id="mobilePaneFader"></div>
  </div>
  <div id="whiteOut">
  <img id="loader" alt="loading" src="resources/images/loader/loader.gif"/>
  </div>
  <!-- Fatal error box -->
  <div id="fatalError">
  <table border="0">
  <tr>
  <td width="70px" align="center" id="fatalError-icon"></td>
  <td id="fatalError-msg">
  <b class="error-title"></b>
  <p class="error-msg"></p>
  </td>
  </tr>
  </table>
  </div>
  <script type="text/javascript" src="lib/jquery-1.7.2.min.js"></script>
  <script type="text/javascript" src="lib/IconSpecs.js"></script>
  <script type="text/javascript" src="lib/common/helper_functions.js"></script>
  <script type="text/javascript" src="lib/jquery.animate-colors-min.js"></script>
  <script type="text/javascript" src="lib/idangerous.swiper.js"></script>
  <script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
  <script type="text/javascript" src="//js.arcgis.com/3.14/"></script>
  <script type="text/javascript" src="lib/colorbox/jquery.colorbox-min.js"></script>
  <script type="text/javascript" src="app/js/main.js"></script>
  <!--Google Analytics Start-->
   if (window.location.href.toLowerCase().indexOf("storymaps.esri.com") >= 0) {
   var _gaq = _gaq || [];
   _gaq.push(['_setAccount', 'UA-26529417-1']);
   _gaq.push(['_trackPageview']);
   (function() {
  var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
    ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js';
    var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
  </script>
  <!--Google Analytics End-->
  </body>
</html>
TravisGallo
Travis
