Combo Box : List unique values for a field (error)
1359
03-17-2016 07:58 PM
johnmarino2
I have built an Addin that has four combo boxes and a button.
combo box 1 provides a list of layers in the TOC (working)
combo box 2 takes user text input for a unique ID field (working)
combo box 3 provides a drop down with a list that displays all the fields in the selected layer (from combo box 1)
combo box 4 will provide a list of all the values for the selected field (from combo box 3)
Combo box 4 is broken, and when I click in the drop down window the python windows displays the following error:
AttributeError: value
The scripting is posted below. I can add the rest if needed. Thank you all very much for the assistance.
class ComboBoxClass3(object):
    """Implementation for SecureSurveyDefinitionQuery.toolbar_1 (ComboBox)"""
    def __init__(self):
        self.editable = True
        self.enabled = True
        self.dropdownWidth = 'WWWWWWWWWWWWWWWWWW'
        self.width = 'WWW'
        def onFocus(self, focused):
            if focused:
                values = [row[0] for row in arcpy.da.SearchCursor(LayerName, attName)]
                uniqueValues = set(values)
                self.items = []
                for uniqueValue in uniqueValues:
                    self.items.append(uniqueValue)
                pass
    def onSelChange(self, selection):
            global SurveyCode
            val = (self.items, selection)[1]
            SurveyCode = str(val)
            field = '"SURVEY_FILE_ID"'
            queryStr = str(field) + "= " + str(Survey_File_ID) + " AND " + '"' + str(attName) + '"' + " =" + "'" + str(SurveyCode) +  "'"
            mxd = arcpy.mapping.MapDocument("CURRENT")
            df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
            for lyr in arcpy.mapping.ListLayers(mxd, LayerName, df):
                if lyr.supports("DEFINITIONQUERY"):
                    lyr.definitionQuery = queryStr
            arcpy.RefreshActiveView()
            del mxd
